SailNet Community - View Single Post - Cal Owners
Thread: Cal Owners
post #17 of Old 04-09-2013
Sootydan
Sootydan's Avatar
Cal Owners
I' a Cal 2-30 owner in boston, ma. Im replacing my prop shaft as i had to cut it out when installing a new PSS shaft seal Boat isnt blocked high enough at the marina to drop the rudder down far eniugh to remove it so i had to cut it in 3 pieces then ill install everything including new cutless bearing when they put the boat in the traveling sling and i can remove the rudder. Saves me $300 to reblock the boat Did some minor epoxy repairs around the keel bottom, lught sanded and washed down the hull, bottom painting today with PETTIT Hyrdocoat. Replaced my bilge pump with a johnson 2200 and ultima switch, new blower hoses for the bilge vent, finishing some wiring for cabin lights, wiring new head pump and generally cleaning up all around. If i have time i may repaint topsides but im not losing sailing time to do that so maybe next season, we'll see
Busy lol
Sootydan is offline
