SailNet Community - View Single Post - Outboard motor bracket
post #10 of Old 04-09-2013
dave22q
Re: Outboard motor bracket
sounds like incompatible uses-- dinghy low power short shaft. auxulary moderate power long shaft. unless your boat is configured to use an auxilary outboard you have a number of issues starting with how you start, shift or adjust throttle. hanging a swing bracket on the stern will create an access issue unless you have 5' arms
dave22q is offline
