SailNet Community - View Single Post - Bluewater defined?
post #20 of Old 01-05-2007
Sailing dog:
“I doubt anyone has the STIX ratings published, as much will depend on how you have the boat loaded and rigged, and where you have supplies and equipment stowed”.
Hellosailor:
"Can anyone point me to a URL listing various boats and their STIX ratings, so I can get an idea of which rates for what?"
PCP:
Sorry for taking so long in repling, but I don’t have been around this Forum.
The stix doesn’t change that much with the boat loaded, unless you load it over the Maximum load capacity. Anyway now they have to show the calculations for two STIXs, One in the minimum loading displacement and the other in the Max loading displacement. Normally the difference is not bigger than 1 point.
I will post my opinion about the STIX, as posted in another boatforum and some others more relevant as well as a short list with sailboat’s STIXs.
STIX:
STIX it is an evaluation for an existing Yacht about its stability and seaworthiness. It is intended not for professional, but for the common user, just to give him a correct idea of the seaworthiness of a given boat.
It is in that sense that RYA says that: “just the same way it is mandatory for the fuel consumption of all new cars to be published…that stability information should also be available to a buyer of a boat”.
STIX is only an easily understandable index (but found through a complicated calculation that takes into account a lot of different stability factors) that is in my opinion, the most sophisticated stability screening tool available.
Certainly very superior to the old Stability Indexes, that in many cases were very misleading and were not unified. I mean, you needed to take a look at several to have an idea of the boat, and many times a wrong idea, mainly with modern deep drafted bulbed yachts.
Don’t get me wrong, it is not a perfect tool, (only the best until now).
Personally I take a look at the STIX for having a general idea, but my evaluation is done independently by the analysis of the RM curve and done by a close examination of the boat (and I mean not a virtual one), with answers about the way it is built and the kind of materials that are used. Special incidence in the way the keel is fixed to the boat, about the rudder and about the hatches and all the “glass” surfaces and the way they are secured to the boat. Not that these are the only important points, but if special care is taken with these ones, there is a good possibility that all the others are well taken care of.
But for understanding a RM curve correctly you have to know a lot more.
STIX is just a number and its interpretation could not be simpler: The bigger, the better.
The RYA view about STIX:
“STIX is arguably the most sophisticated stability screening tool yet available. ….
Since June 1998 all new recreational boats sold in the EU have been required by law (the RCD*) to have undergone a stability assessment with the preferred method being the application of ISO 12217. “
http://www.rya.org.uk/NR/rdonlyres/43D83922-ED3E-4D5D-BBCF-6A14AA352EFA/0/StabilityIntro.pdf#search=%22stabilityintro%20pdf% 22
The Paul Miller view (D. Engr., from the Dept. of Naval Architecture of the United States Naval Academy:
“The Best we have…”
Bob Johnson view: (Naval architect, the Island Packets designer and the U.S. participant on the international work group of designers and naval architects responsible for developing STIX):
… STIX standard, I think, encompasses all critical stability factors in an analytical method that is based on established principles of naval architecture, sound methodology, and correlates well with real-world experience for real boats. No other single stability-assessment method, to my knowledge, is as comprehensive as STIX.
BENETEAU 50 AVS 109 STIX 41
BAVARIA 42 STIX 36
BENETEAU 50 STIX 41
BENETEAU 57 STIX 53
CATALINA 34 MK11 STIX 36
CATALINA 42 40 AVS 105
COMET 36 STIX 32.5 AVS 127
CONTESSA 32 STIX 33 AVS 155
CYCLADES 39 STIX 38 AVS 126
CYCLADES 43 STIX 36 AVS 121
DISCOVERY 55 STIX 37 AVS 122
ELAN 37 STIX 40 AVS 136
ELAN 40 STIX 37 AVS 128
ELAN 44 STIX AVS 124
ETAP 32 STIX 36 AVS 122
ETAP 34 STIX 37 AVS 123
ETAP 37 STIX 42 AVS 123
FIRST 36.7 STIX 34 AVS 126
FIRST 40.7 STIX 37 AVS 126
FIRST 42.7 STIX 35 AVS 118
FIRST 44.7 STIX 41 AVS 130
FIRST 47.7 STIX 46 AVS 123
FISHER 34 STIX 33 AVS 180
FISHER 37 STIX 43 AVS 180
HANSE 371 STIX 35 AVS 122
HANSE 411 STIX 33 AVS 128
HANSE 461 STIX 35
HANSE 531 STIX 39
HARLEY REFLEX 38 STIX 41 AVS 143
HOD 35 STIX 41 AVS 140
HUNTER CHANNEL 31 (single keel) STIX 32 AVS 130
HUNTER CHANNEL 31 (twin keel) STIX 33 AVS 130
HUNTER CHANNEL 323 STIX 35 AVS 149
ISLAND PACKET 350 STIX 49 AVS 141
ISLAND PACKET 370 STIX 43
ISLAND PACKET 380 STIX 55 AVS 136
ISLAND PACKET 420 STIX 59 AVS 136
ISLAND PACKET 440 STIX 48 AVS 133
ISLAND PACKET 445 STIX 53 AVS 141
ISLAND PACKET 485 STIX 66 AVS 143
J12O STIX 43 AVS 127
J100 STIX 37 AVS 126
J125 STIX 42 AVS 131
J133 STIX 46 AVS 130
J145 STIX 52 AVS 139
J160 STIX 57 AVS 118
J42 STIX 45
J46 STIX 48 AVS 127
MALO 45 STIX 62
MISTERY 35 STIX 32 AVS 156
NAJAD 380 STIX 43 AVS 128
OCEANIS 343 STIX 34 AVS 134
OCEANIS 351 STIX 35 AVS 125
OCEANIS 361 STIX 32 AVS 120
OCEANIS 36CC STIX 35 AVS 126
OCEANIS 373 STIX 36 AVS 132
OCEANIS 381 STIX 38 AVS 130
OCEANIS 393 STIX 43
OCEANIS 411 STIX 37 AVS 114
OCEANIS 423 STIX 38 AVS 119
OCEANIS 44CC STIX 34 AVS 110
OCEANIS 461 STIX 37 AVS 115
OCEANIS 473 STIX 48 AVS 119
OCEANIS 523 STIX 46 AVS 111
OCEANIS 42CC STIX 38 AVS 38
SEAQUEST 32 STIX 37 AVS 132
SEAQUEST 36 STIX 46 AVS 142
SEAQUEST PRIMA 38 STIX 52 AVS 131
SOUTHERLY 110 STIX 55 AVS 151
SOUTHERLY 115 STIX 51 AVS 150
SOUTHERLY 35RS STIX 37 AVS 160
SOUTHERLY 135 STIX 54 AVS 139
SUN ODYSSEY 37 STIX 33
SUN ODYSSEY 39i STIX 33
SUN ODYSSEY 40DS STIX 37/39
SUN ODYSSEY 40.3 STIX 36/38
SUN ODYSSEY 43/43DS STIX 44
SUN ODYSSEY 52.2 STIX 50
SUNFAST 35 STIX 33 AVS 127
SUNFAST 37 STIX 32
SWAN 40 STIX 36 AVS 112
SWAN 44 STIX 38 AVS 123
SWAN 45 STIX 57 AVS 134
SWAN 46 STIX 53 AVS 128
SWAN 48 CR/R STIX 49 AVS 135
SWAN 56 R STIX 50 AVS 127
SWAN 56 R/C STIX 55 AVS 124
SWAN 57 RS STIX 53 AVS 132
SWAN 60 R STIX 68 AVS 128
SWAN 60 R/C STIX 70 AVS 122
SWAN 601 STIX 84 AVS 153
SWAN 62 STIX 63 AVS 122
SWAN 68 R STIX 76 AVS 127
SWAN 70 STIX 82 AVS 133
SWAN 75 R STIX 81 AVS 121
SWAN 80 R STIX 80 AVS 138
SWAN 82 R STIX 88 AVS 127
VANCOUVER 28 STIX 36 AVS 170
VANCOUVER 34P STIX 35 AVS 166
VANCOUVER 34C STIX 36 AVS 139
WARRIOR 40 STIX 47 AVS 133
WESTERLY OCEAN 43 STIX 40 AVS 129
X YACHTS 37 STIX 35 AVS 123
X YACHTS 40 STIX 37 AVS 113
X YACHTS IMX 40 STIX 47 AVS 132
X YACHTS 43 STIX 40 AVS 119
X YACHT IMX 45 STIX 46 AVS 124
X YACHT 46 STIX 44 AVS 123
X YACHT 562 STIX 57 AVS 122
X YACHT 612 STIX 51 AVS 110
X YACHT 70 STIX 73 AVS 126
X YACHT 73 STIX 84 AVS 121
