SailNet Community - View Single Post - Proper way to tap into 12VDC wire?
post #29 of Old 04-09-2013
L124C
L124C's Avatar
Re: Proper way to tap into 12VDC wire?
Originally Posted by sstuller View Post
You could try a Posi-Lock connector (Posi-Lock(R) - The Best Connectors You'll Ever Use!). They have one that can be used to tap into a line. Thanks. Steve S.
The only connector they claim is water tight is the Posi-Tite in line connector. The Posi-Tap would be the connector that would work for my application.
Posi-Tap- No Crimp Tap .While they recommend some of the other connectors for outdoor lighting and marine use, it's not mentioned for the Posi-Tap. Guess I could seal it with liquid electrical tape, but it would make a mess of what was a elegant solution. Interestingly, they claim their Posi Twist connectors eliminate 80% of the resistance of crimp-on connectors. If accurate, thats a lot! But then...maybe you could say the same about regular twist locks, as the wires touch in the same manner.
Looks like you can only get them from Crutchfields. Has anybody used the connectors? What about the resistance claim?
L124C is offline
