SailNet Community - View Single Post - Bearing Buddies for trailers
post #3 of Old 04-10-2013
tommays
tommays's Avatar
Re: Bearing Buddies for trailers
I will post a few pictures later
Keep in mind they ONLY put a bit of grease on the outer bearing as it cant travel across the spindle to the inner bearing which is most subject to water intrusion from a leaking inner seal
The newer drilled axels that have a grease passage to the inner bearing are vastly better
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
