SailNet Community - View Single Post - freedom 2500 watt inverter
post #3 of Old 04-10-2013
mitiempo
mitiempo's Avatar
Re: freedom 2500 watt inverter
Originally Posted by norahs arc View Post
Re generator size (2800 watt)
Probably not. When the generator is charging the batteries it it must also handle the AC loads.
The other loads can be turned off as necessary. Even the Xantrex 3000 watt sine wave inverter/charger works just fine on a 30 amp shorepower connection - both charging and handling loads.
Brian
mitiempo is offline
