SailNet Community - View Single Post - Modern Hull forms and Motion Comfort
post #96 of Old 04-11-2013
bobperry
grumpy old man
Re: Modern Hull forms and Motion Comfort
I agree Jeff on the SA/D aspect of the added weight. But and this is a big but, I still think the lighter boat will be the better performer. One number doesn't tell the entire story. Remember the lighter boat in all probablity would have started with a much higher SA/D to begin with. Your typcal D/L 250 cruiser would probably have a SA/D around 17.00before loading. While the lighter boat most probably would have SA/D around 20.00 and maybe even higher before loading. Add the extra weight and the light boat in almost all cases would still have a higher SA/D or at the least the same SA/D as the heavier boat.
Let's do the math:
A 24,000 lb. boat with 850 sq. ft. of sail area (Valiant 40 specs) will have a SA/D of 16.34 prior to loading.
Load on 2,700 lbs. of gear and the SA/D drops to 15.22
A 14,000 lb. modern boat with 800 sq. ft. of SA will have a SA/D of 22.00 prior to loading.
Add the 2,700 lbs. of gear and the SA/D drops to 19.59.
Even if I cut the rig down on the light boat to 700 sq. ft the loaded SA/D is still 17.1.
Bob's Blog ....
bobperry is offline
