SailNet Community - View Single Post - Bearing Buddies for trailers
post #10 of Old 04-11-2013
tommays
tommays's Avatar
Re: Bearing Buddies for trailers
As a matter of fact I am and expert
stage one
stage two
Stage three
They there always leak the rear sealing area is mild steel and fails even in freshwater
They invented SS speedy sleeves to fix issues as it now has a surface a seal can stay alive on and NOT rust ASAP
They can be driven on over a sealer with some caution and primitive tools
They leave you with a PERFECT SEALING area that will NOT leak
Smart people still spend the two hours once a year to check
And travel with a road kit
The bore area were the buddy installs has a primitive size tolerance on a good day and depending on the hub they are between a hand fit and a sledgehammer
They do allow for a bit of thermal expansion BUT still only lube the outer bearing which already has plenty of grease
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
