SailNet Community - View Single Post - seized, broken bolt Boston
post #2 of Old 04-12-2013
downeast450
Tundra Down
downeast450's Avatar
Re: seized, broken bolt Boston
roper,
I had a similar problem and managed to drill out enough of the center of the bolts to collapse them inward with a small punch then extract the hollow remnants. I started very carefully with a small diameter bit then continued to remove material from the center by increasing the drill size.
Good luck.
Down
downeast450 is offline
