SailNet Community - View Single Post - seized, broken bolt Boston
post #10 of Old 04-12-2013
tommays
tommays's Avatar
Re: seized, broken bolt Boston
I am often forced to do hand work on stuff that cant be carried to a machine
The value is such I would carry it to a machine (I have the machines ) if you can
On and Atomic 4 block for example the 18 head studs fail here and there and after cleaning up and using the still good studs and the head as a drill guide works well
You just need to buy a letter size drill that exactly fits the clearance in the cylinder head and use this drill to spot the hole so it is exactly centered
You can then drill through with the right size drill and the head will serve as a guide in keeping a hand drill true and a good taping guide
On really crazy stuff I can drill up a guide on the Bridgeport in a few minutes
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
