SailNet Community - View Single Post - Dousing a cruising asym without blowing the tack?
post #11 of Old 04-12-2013 Thread Starter
peterchech
Re: Dousing a cruising asym without blowing the tack?
Originally Posted by blt2ski View Post
How many people do you have on board? if only one or two, a sock is best and easiest. If you have 3+, then you raise the jib, pull down behind the jib letting the halyard down as you might a sym spin. Yeah we will let the tack lose, but not a lot! most is down by letting the halyard down using the jib/genoa as a blanket. I think Ihave some pics somewhere. Altho I am thinking it might be dousing with out the jib......hmmmmm.....need to find them pics dodenja took at the end of a race with my kids/crew sailing the boat. I was rc in the major regatta we do........
I also agree, that an actual tack line attached forward of the forestay makes things MUCH easier. THen run that line to the cockpit.
Marty
Usually two up
Outside the jib drop seems overboard no? I'm short handed and not racing, don't have enough hands I think...
peterchech is offline
