SailNet Community - View Single Post - Liveaboard racer-cruiser?
post #5 of Old 04-12-2013
hellosailor
Re: Liveaboard racer-cruiser?
I'm told that the Cal40 was sometimes sold as a "kit boat" and if that's true, what you find in each one may vary. I was on one with a deck stepped mast, which many folks would consider unacceptable, and told the factory stepped them on the keel. I don't know if any part fo that is true, but the Cal40s do have a reputation for being a fast stable boat.
When you look at any racer-anything with thoughts of moving onboard, bear in mind the hull is usually designed for a fairly light racing payload and that if you pile up a home onboard, you may push the waterline up. So consider how many pounds of crew she was intended to carry, and compare that to what you'll be bringing onboard too.
hellosailor is offline
