post #3920 of Old 04-13-2013
Sapwraia
Re: Clarc33
I don't know why I never talked about this one: It is so pretty ...and fast too. Speed with style on a boat that has a variable draft with a bulbed lifting keel: from 1.25m to 1.95m .
Lots of the ballast for the weight, type of keel and draft: 40% of B/D ratio on a very light boat (2.850kg) allows a relativelly narrow hull (2.54m) with a more than decent sail area (51/46 sqm). The light weight means an high tech construction with Vacuum-Infusion, Epoxy resins, bidirectional E-Glass use of carbonfibre fibre and light wooden elements.
a wolf in disguise
If something can be said against is that the boat has not a proper head, just a chemical one and the galley is really minimal. This makes it a weekend cruiser at most... but a boat that will let many astonished at club race and that certainly will put a big smile on the face of the one at the tiller. However I think the boat deserved a better interior one as well done and as beautiful as the rest of the boat: That would be perfection.
Nice - Looks more complete than some other recent retro daysailer/weekenders of similar size. I like the way the rudder being set well aft means they've kept the tiller substantially out of the cockpit. I also like the tapered coach roof profile, but those oval ports don't work for me being same size - esp the fwd one - to pull this off to best effect they should have the ports reducing in size with the taper. I presume they're using stock components, but visible details like that make all the difference in this segment which is getting quite competitive; and target buyers will be very particular about spec & detailing.
Sapwraia is offline
