SailNet Community - View Single Post - Hull-deck joint - suggestions needed Int'l Folkboat
post #2 of Old 04-15-2013
tommays
tommays's Avatar
Re: Hull-deck joint - suggestions needed Int'l Folkboat
The curse of the molded fiberglass toe rail
My Cal 29 suffered from the same issue
The caulking rework is the only reasonable thing to do outside
That is dig it out and caulk it again as with some careful taping you can do a neat looking job
If there is and issue with the joint failing in some manner , why else would it leak
And inside repair while messy does not shine a spotlight your work
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
