SailNet Community - View Single Post - Tartan 3500 Anchor Locker Leak
post #5 of Old 04-15-2013
Doug
Re: Tartan 3500 Anchor Locker Leak
Jimgo. Thanks for suggestion. I could create a higher floor for anchor locker but then I need a hose connection to drain opening. Once installed there is no way to access the hose and coNnect to the hull drain. And there is no fitting on the hull drain so I would be gooping up the connection- not a good idea for one term Maintenance.
Problem today is sea water comes in thru the hull drain and then runs to bottom of hull and ends up in bilge. I'm thinking I should seal off the thru hull drain .
Doug is offline
