SailNet Community - View Single Post - Wish I Had The Boat Builder/Dealer Do It!
post #14 of Old 04-15-2013 Thread Starter
opc11
Re: Wish I Had The Boat Builder/Dealer Do It!
Paul,
Except for the Tayana 42, all of my boats have been new.
There are some things that are really better installed at the factory if you can. The generator (diesel) is one. You might also consider them installing your air conditioner... maybe.
I installed my solar, charging system, battery system, inverter, some of my electronics, heads, and other comfort items.
My suggestion, as a cruiser, is that you do what you can yourself. You will not necessarily save money. In fact, depending on your boat, it may cost you more money. But you can see how it goes in and where you drill your holes, what cabinets you take out, where the runs are, etc. Your factory will not necessarily care if they take out a whole cabinet for a duct run, whereas you will want to maximize your cabinetry as much as possible, or you might want a tank there and don't want that run through that spot. They cannot read your mind (and most of them may not care).
I cannot stress how important it is when cruising to know where your runs are for everything. Otherwise, when something breaks, you are scrambling to find where it is run... not to mention what is broken. Make sense? THis is especially true with the electronics which love to screw up and get outdated.
The generator is just such a bulky and multi-man job, its is something we opted to have done. And the factory at times can put it in cheaper than what you can after-market it for because they already have the boat apart. Do be careful though that when you have factory installed items, THEY CAN STILL COME BACK OUT! Very important. You will eventually replace it all or might want to.
My experiences.
Brian
Brian,
Thanks a bunch! That's the type of info I was looking for. I couldn't agree more about knowing where the runs are and there is a definite benefit to installing items yourself in terms of knowledge.
One thing that seems missed by many boat builders is the idea that at some point someone is going to be servicing what they've installed....and it may happen in the middle of nowhere. I wish builders considered this more in their assembly.
Thanks again!
opc11 is offline
