SailNet Community - View Single Post - Tartan 3500 Anchor Locker Leak
post #6 of Old 04-16-2013
jimgo
Asleep at the wheel
jimgo's Avatar
Re: Tartan 3500 Anchor Locker Leak
Doug,
Sorry, I should have been more clear. I was suggesting sealing off the lower drain, then putting in a new one higher up.
Are there any check-valves or the like that you could put in line with the drain? It probably wouldn't take much, just a "flapper" that would close off the hole. You might wind up with a bit of water pooling in the anchor locker, but it sounds like that might be better than having the seawater come in and swamp the boat.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
