SailNet Community - View Single Post - AC condensate drainage
post #25 of Old 04-16-2013
dsmauney
I'm using a 684 on a 16000 BTU unit and it is working fine. Flow seems OK as unit performance seems no different. 684 has a built in check valve and I put in a second plastic check valve from US plastics. If venture stops working condensate will continue to go to bilge through drain hole like it did before. Sure keeps most of pan dry. I only run unit when I am on board.
Goodwinds
DaveM
dsmauney is offline
