SailNet Community - View Single Post - Wanted- Otto, Dead or Alive
post #16 of Old 04-17-2013
Skipper Jer
Skipper Jer's Avatar
Re: Wanted- Otto, Dead or Alive
Have you opened otto up and looked around? Take a look for bulgy electrolytic capacitors and goop leaking from said caps. Pardon my ignorance but doesn't this unit have a 4 position rotary switch of which one position is off? I noticed you said remove power as in disconnect it from the source, instead of turn it off. Why putting the switch in the off position doesn't do the same as disconnecting the power source may be worth looking into.
Nor'sea 27
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is offline
