SailNet Community - View Single Post - Exhaust Manifold Flooding with Cooling Water
post #9 of Old 04-17-2013
hellosailor
Re: Exhaust Manifold Flooding with Cooling Water
" In would be imposible for an electric pump to do this "
You are forgetting, there is no need for the electrical pump to mimic a WEAKNESS of the mechanical pump. Regardless of the pump type there should be a thermostat, which is restricting the flow according to thermal needs.
So it doesn't matter how the flow rate from the pump varies, the thermostat has the only opinion that matters there.
hellosailor is offline
