SailNet Community - View Single Post - What to do if a shroud or stay breaks
post #6 of Old 04-18-2013
outbound
outbound's Avatar
Re: What to do if a shroud or stay breaks
As said above change point of sail to unload broken stay. If you have running backstays reef so sail below point of attachment and deploy. If you have spare halyards use to replace function of broken stay. If halyard external attach one end to chain plate. Attach block as close to possible to chain plate. Then run other end through block and tension with winch. ( may need to secure additional line to tail of halyard to effect. Can also use topping lift if no halyards available. If stay with roller furling on it secure rolling furling gear to bow pulpit or toe rail asap and drop sail if possible.
s/v Hippocampus
Outbound 46
outbound is online now
