SailNet Community - View Single Post - Islander 28 propeller location from shaft support?
post #3 of Old 04-19-2013
divefreak
Bilge-Hamster
divefreak's Avatar
Send a message via Skype™ to divefreak
Re: Islander 28 propeller location from shaft support?
Originally Posted by 510datsun View Post
I'm going to replace my prop shaft, its bent, worn in grooves, and appears to short. My prop is within an inch or two of the shaft support.
Sounds perfect!
rule of thumb 1 to 2 times the diameter of the propshaft from the last support
so with a 1 inch shaft what you should have 1-2 inch would be ok
Regards René
divefreak is offline
