SailNet Community - View Single Post - Topside makeover
post #9 of Old 04-19-2013
Tim R.
Tim R.'s Avatar
Re: Topside makeover
Originally Posted by sailkittiwake View Post
Here is a shot of the decals removed. This took me a while to figure out. I found that the best method was to heat the edge so I could rub it up and grab it. Once I had something to pull, I put the heat gun in my other hand, about 3 feet down and then would pull. It was critical to keep the gun and the edge that far apart at all times because if you get too close the tape melts or breaks. Just keep your arms in the same position and walk along.
Untitled
Great technique but you can accomplish the same thing with a hair dryer. Much safer for both you and your gelcoat. Also less chance to melt the vinyl.
Nice work. 80 gril sanding seems aggressive. Did you try finer grits first with no success?
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
