SailNet Community - View Single Post - propane for bloxygen
post #1 of Old 04-20-2013 Thread Starter
davidpm
davidpm's Avatar
I read a tip where someone exhausts a little propane in the top of a partly used can of paint or varnish to displace the air.
Is supposed to prevent the material from hardening.
I've been trying it.
I have a small propane torch. The trick is to press the button enough so the propane is released but not so much as to light the torch.
davidpm is offline
