SailNet Community - View Single Post - Can't drop gear case to change impeller on Tohatsu 6HP
post #8 of Old 04-20-2013
dabnis
Re: Can't drop gear case to change impeller on Tohatsu 6HP
Originally Posted by dabnis View Post
Try this one, I have the same motor, standard shaft, I will see if I can find any "hidden" bolts.
2011 MFS6C Tohatsu Outboard GEAR CASE, DRIVE SHAFT & GEAR CASE, PROPELLER SHAFT Diagram and Parts
Paul T
On mine, the only bolts I can see are bolts 53 & 55. There is a member by the name of pvann---? who is a Tohatsu rep. He may be able to help you, or maybe your local dealer could tell you what the trick is?
Paul T
dabnis is offline
