SailNet Community - View Single Post - Blue Sea Battery meter with two banks
post #1 of Old 04-20-2013 Thread Starter
Rusty123
I'm replacing the high current wiring on my boat -- two banks, primary and reserve. The boat already has a voltage/amp meter (Blue Sea 8248).
There is a good thread about installation of a shunt with two banks at this thread, but that's for a Victron meter, which is designed with two voltage inputs.
The Blue Sea meter only has one voltage input, so measuring voltage on two banks requires the installation of a switch on the voltage sensing lead. Blue Sea has a nice tutorial here.
But here's the rub: Blue Sea says that to measure voltage on two banks, the banks must share a common ground (that is, both connected to same side of shunt). But as described in the Victron thread, connecting both banks to the same side of the shunt will prevent monitoring of bank-to-bank current (although this would seem to complicate consumption calculations).
Since the voltage drop across the shunt is so small, I'm inclined to ignore the Blue Sea direction, and connect the bank negatives the way Victron describes.
Does anyone see any "gotcha's" with this plan?
Rusty123 is offline
