SailNet Community - View Single Post - My last little bit of planning
post #21 of Old 04-22-2013
Minnewaska
Re: My last little bit of planning
Originally Posted by northoceanbeach View Post
Lazarettes, thank you.
THe, lazarettes, are good in that they are sealed from the cabin.
More than 10 gallons huh? How much would you recommend? I could probably fit 12 -15 in one lazarette comfortably. Right now I have 6, and 3 life jackets, and alot of room.
I'm not a fan of putting gasoline inside anything, sealed or otherwise. The vapor are highly explosive in a range of air mixtures. No thanks.
Lash spares to the deck, bottom of the mast or side decks, if you must. Just keep in mind where the gas will go, if the tank leaks.
Jeanneau 54DS
Minnewaska is offline
