SailNet Community - View Single Post - Removing painted letters
post #5 of Old 04-22-2013
DrB
Easy Off isn't "Easy Off"
I have painted letters on my boat that are starting to fade, crack and peel. Tried the Easy Off approach last night with no success. A little comes off, but not much. I even let it sit for 5 minutes and no enhanced results.
The Admiral recalls that the PO said the letters were painted on with "automotive" paint, which means it could be urethane,acrylic,enamel, epoxy,etc.
So I need a safe way, besides Easy Off, that I can use on gel coat, to get these off. Would one of the Soy-based strippers work? I could probably sand them off with 1000 grit, but then I have to recondition the original gel coat on a 1979 boat in that area.
Thanks.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
