SailNet Community - View Single Post - Why a racer for cruising discussion...
post #65 of Old 04-22-2013 Thread Starter
Cruisingdad
Best Looking MALE Mod
Cruisingdad's Avatar
Re: Why a racer for cruising discussion...
The average couple is a cruiser so having the solar and wind generator should be enough with the large battery bank. Less hot water needed also therefore less storage. Less water needed therefore less storage.
You have to also add weight in fuel, pumps, shield etc. for the generator weight not just the generator.
Dave,
I think you will end up having a generator no matter what. I also am not sold on having a huge battery bank. The power required to refill that bank, after a few cloudy days, may be more than you can produce - especially considering you not only have to replenish but you have to make enough for that day to keep up with your daily loads.
The hot water killer is showers and washing dishes. The washing dishes is the same no matter how many are on board (pretty much anyways). The shower use is surprisingly small. I measure out how much water (total) I use when I shower. Conservative, I will use about 1.5 gallons. Really conservative I have gotten it under a gallon. There are some tricks to doing this, but unless you want a mutiny, you figure out real quick how to conserve the hot water. My point is that you will go through more hot water with 4 people versus two, but not as much as you might think.
The water is a bit of a different story. The actual cooking for two will not be that much less than with four people, but four people will drink twice as much water as two. The modern method for this is to buy a watermaker, then you don't have to worry about it much, but still an issue. THen your water supply is dependent on how much diesel you have, or how much electricity you make if you get a Spectra type watermaker.
Just some thoughts.
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
