SailNet Community - View Single Post - Can't drop gear case to change impeller on Tohatsu 6HP
post #17 of Old 04-23-2013
dabnis
Re: Can't drop gear case to change impeller on Tohatsu 6HP
I kind of got lost in your description of the linkage. If all you did was to disconnect the coupling, I would think just re-coupling it with the original marks would do it? However, if you took the drive shaft out of the gear casing, that may be another story? Pictures?
Paul T
dabnis is offline
