SailNet Community - View Single Post - Using Bottom Paint on Brass Propeller
post #17 of Old 04-24-2013
JimMcGee
JimMcGee's Avatar
Re: Using Bottom Paint on Brass Propeller
Sheesh MaineSail, thanks for adding one more thing to my spring to-do list.
I've got the prop off right now to do the cutlass bearing. It was painted with Micron after the application of a primer coat, though I'm not sure what primer the yard used.
I'll take the paint off using a brass wire wheel as the old paint is knicked up and check the condition of the prop.
Is it OK to re-coat with a primer-paint combo as Lancelot is doing or better to just use the Petit barrier coat?
Thanks,
Jim
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
