SailNet Community - View Single Post - Prop Shaft Coupling
post #4 of Old 04-24-2013
Alex W
no longer reading SailNet
Alex W's Avatar
Re: Prop Shaft Coupling
It is easy to make a proper removal tool if you have access to a drill press. Do this instead of the socket approach. Here is a photo of one that I made out of 1/4" plate steel:
The 4 bolts are attached (with nuts) to the shaft coupling. The 1/2" bolt in the center is tightened (the plated is threaded for it) and pushes the shaft out of it. This took about 20 minutes to make.
Alex W is offline
