SailNet Community - View Single Post - Islander 28 propeller location from shaft support?
post #11 of Old 04-24-2013
dacap06
Send a message via Yahoo to dacap06
Re: Islander 28 propeller location from shaft support?
Originally Posted by 510datsun View Post
I'm guessing you didn't read the first message I posted at the start of the thread, but I will recap it for you.
In my initial post at the start of the thread, I stated I have an electric motor. The HP rating for electric and combustion engines is different because of the character differences of the two. I have been told the electric motors are more like the diesel vs a gas, more torque, and lower RPM versus a gas motor. So, trying to us a general formula for a combustion engine I don't think would work. An electric 5 hp rated motor would be close to the out put of 10-15 HP gas, so I have been told.
I don't have a transmission, but my pulleys are 2:1 from the motor to the prop shaft. Would be hard to plug my set up in to the formula.
I also initially posted, I have an Islander 28, I'm guessing since you wanted a hull, I have a 1976, hull #23. I was just trying to get an idea of what the diesel owners of the 28 were running to compare their's to what I have, to see if I'm OK with what I have.
In my first post, I stated I have a 3 blade 12x10.
So, kinda back to my initial question at the first post.
What prop are the owners of Islander 28 with diesel engines using?
Just looking for a general feel from the Islander 28 community
Thanks for wanting to help out, says a lot.
Thanks for the recap, 510. It looks like no one from the I28 community is responding. I'll contribute what what estimates I can based on my I30 experience and my EE degrees and experience.
Before I get started, I want to say most emphatically that you are best off talking with a reputable company that makes propellers, but one should never place blind trust in any so-called expert. You should always have a good idea of what the answer should be. That's my motivation for finding an estimate.
I will assume the usual size diesel engine for the 7000 lb I28 is an 11 or 12 HP (remember, that's diesel only). I base that on the fact that my 8300 lb I30 has a Yanmar 13HP 2GM(F) in it, and the more usual Volvo for my model is also a 13 HP model. But what we really need to know is not horsepower though, but torque. Sadly, Yanmar does not publish torque curves for its engines. Without giving you all the boring details, I'll say that my estimate of maximum torque for the 2GM is about 18 ft-lb based on other engines of similar size and RPM range. I expect you'd want something similar if you were to get a diesel engine.
My boat came with a Michigan Wheel 13x10 2-blade prop. It got me up to about 6.5 kts at 3500 RPM WOT, so it was about right for my 18 ft-lb of torque coupled to its 2.21 drive ratio transmission. But I was never happy with the way it backed down so I recently purchased a 3-blade 13x7 Campbell Sailor and have been much happier. I gained a half knot for the same RPM at cruising speeds and reverse is now actually useful. Interestingly, West by North Enterprises recommends a 13x8 if you have the more usual 2.61 transmission with a Yanmar 2GM.
The next part of estimating can be tricky and depends heavily on what kind of electric motor you have and its specs. Five HP DC motors are fairly rare. Most controllable motors are A/C even when battery powered. Generally, when an electric motor is battery driven, the DC power from the batteries runs through an inverter and goes to a cycloconverter or some sort of modulator such as a pulse width modulator, so it isn't beyond the realm of possibilities that you have an AC motor.
So we need to know some basics. Do you know the brand and model of your electric motor so maybe I can find it in my literature? Failing that, is it AC or DC? Operating voltage is useful too, if you have it. Is it a standard induction motor (by far the most common type of AC motor), a synchronous motor (almost unheard of in variable speed applications), or what? It makes a difference because the torque curves for the different motor types are very different.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
