SailNet Community - View Single Post - Prop Shaft Coupling
post #9 of Old 04-24-2013
CalebD
Tartan 27' owner
CalebD's Avatar
Re: Prop Shaft Coupling
Originally Posted by casey1999 View Post
Is that all that is holding your coupling to the shaft? You have no set screw (I would assume you have a key/keyway)?
I have a solid coupling (not split) and yes, there is a set screw which has to be wired so it does not decide to pull out. So my shaft is held in place at the coupling by the press fit and the set screw.
The key/keyway is on the prop end of my shaft.
See if you can torque down the split sides together. It may work.
Obviously I've never used this shop:
Marine Propellers Hawaii
(808) 537-6772
1100 Bishop St, Honolulu, HI 96813
but it would seem near the Alu Wai and perhaps convenient.
Everybody has one:
CalebD is offline
