SailNet Community - View Single Post - What is the quietest fresh water pump?
post #12 of Old 04-25-2013
Re: What is the quietest fresh water pump?
Originally Posted by svHyLyte View Post
Actually, you can mount the pump on two lengths of 2" (non-wire reinforced) hose with the ends cut off on the diagonal and screwed/bolted to the sole. The flexibility of the hose will substantially reduce the "pounding" noise of the pump. One just needs ensure that the waterlines have enough slack on either side of the pump to flex without damage to the connections. In addition to checking the accumulator bladder, you might also check to ensure that your pressure switch is operating properly and not activating for an unnecessarily high pressure.
Capt. Len,
Do you have a picture or a drawing of this installation? I'd like to try it but I'm not sure I understand how it can be done with only two lengths of 2" hose. Seems like you'd need one for each of the four mounting bolts. Thanks.
jbeahon is offline
