SailNet Community - View Single Post - Tiny Dehumidifiers
post #39 of Old 04-25-2013
jimgo
Asleep at the wheel
jimgo's Avatar
Re: Tiny Dehumidifiers
PDQ - I read your blog post and found it very informative. I'd be curious as to which is more effective, using a dehumidifier or using solar fans. I also wonder whether the set-up of the dehumidifier drain makes a difference. In Take5's case, the drain is to the sink, which is VERY important, because I believe that drains directly outside the boat. By contrast, I've read comments from people who drain into the bilge, with the expectation that the bilge pump will carry it out. But, if the dehumidifier drops the RH enough, doesn't the air become "dry" and won't the water in the bilge simply evaporate back into the boat's air? Essentially you're creating a closed loop.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
