SailNet Community - View Single Post - Minimal Electronics reqirements and alternatives
Old 04-28-2013
slax slax is offline
slax is on a distinguished road
Hello,
I am in the process of refitting, well mostly building up the electronics on my recently aquired 33' Vanguard (bantik). Currently only have a vhf radio, a few local charts, depth finder, and a questionable knot meter. Which works fine for the local area, being tax time I have some resources to add some equipment and put it all into a centralized nav station. Which leads to my first questions.
What do you consider for a minimal nav/comms electronics setup? and What do you consider for an ideal one?
The next one gets a bit more complicated, I have several pieces of gear from other projects (eg: a carputer: embedded fanless dual atom mb/ssd drive/dc power/passive cooled case/etc, several gps capable phones: tested to run the set of data needed for the mapping/gps/etc systems) also solar charge controllers (used in landbased applications) and other custom gear. This leads into my next question I suppose..
I like DIY, so was wondering the communities inclination to using this old gear in place of buying something fancier that could tie easily into the fairly espensive closed source sw from garmin/etc if I buy one of there units in leue of using some home brewed solution...
