SailNet Community - View Single Post - Perkins 4108 Overheating
post #3 of Old 04-29-2013
SimonV
Wish I never found SN!
SimonV's Avatar
Re: Perkins 4108 Overheating
What Chuckles said plus, Have you pulled the exhaust mixer elbow. It can over time coke up, when I did mine it was half blocked with what looked like a chunk of black coal. Also how is Your water trap, that may need a good clean out. Not having a a thermostat should make the engine run cooler. Other causes of overheating blocked or restricted exhaust and or blocked waterways check and flush both. faulty timing of valves and or injector pump will cause overheating. Start with the easy and hope you rectify it before the expensive stuff. Oh and a cracked head is also a cause. run your engine in gear at 2000 revs tied to you dock watch the exhast water it should be spraying out. then get down and watch the engine as it heats up, you may get to see where the steam is coming from. Before you do this just try running the engine at about 1000 revs with the coolant cap off, the coolant should just move as you have no thermostat If it bubbles or is blown out you have major head issues.
Simon
I miss my boat
Brisbane
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
