SailNet Community - View Single Post - Dislodging Edson pedestal bolts
post #4 of Old 04-29-2013
tommays
tommays's Avatar
Re: Dislodging Edson pedestal bolts
Originally Posted by nestorph View Post
I've been prepping my new-to-me Islander 30 and need to run a cable or two up the steering pedestal for the GPS unit. I removed the compass and have been completely stymied by the bolts holding the compass base to the pedestal bowl. Teasingly, one bolt came out fairly easily. It's about four inches long with the bottom two inches threaded and has a flat head. The other three are pretty much welded in! I've tried dousing the entire visible lengths in ProBlast and have even used an impact screwdriver to no avail. Any secret tips on breaking through?
I would be real sure of WHAT you can still buy as my older unit has many NLA items or prices that are
AFTER YOUR INFORMENED you can break the cheapest part to save the best stuff
For example if there is know way there coming out you can cut the bolts at the base of the compass riser and then soak it as a unit
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
