SailNet Community - View Single Post - Back for more - portapotty vs. manual head
post #7 of Old 04-29-2013
Pegu club
Re: Back for more - portapotty vs. manual head
The problem is that the waste out hose from the head travels about thirteen feet through the bilge/ under the cabin floor, then has to gain about two and a half feet to get up to the holding tank that is attached on a bulkhead under the cockpit, past that bulkhead is the lazz locker that holds the outboard. The only place one could maybe move the holding tank to would eliminate all the storage for the galley/ nav table, and it would still be two feet above the waste hose where it exits the head. so I'm thinking that the current head system needs to be removed and a porta potty should be reinstalled.
I know that the head debate rouses many to levels of passion, but a quality new porta potty can be set up for dockside pump out that alone strikes me as reason enough to remove the old poorly laid out head system.
Is the current head system as described above a disappointment just waiting to happen or not? From what Slowbutsteady is saying I think its got to go.
What say you fellow sailers?
1977 Bristol 29.9 #17
A slave to the wind
Pegu club is offline
