SailNet Community - View Single Post - Strange noises from below...
post #5 of Old 04-29-2013
SchockT
SchockT's Avatar
Re: Strange noises from below...
I experienced a chirping noise like you described, and found it was a loose zinc on the propshaft. You may also want to check your cutlass bearing. If you have a folding prop, it may have some slop in the blades, or it may not be opening properly causing an imbalance.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
