SailNet Community - View Single Post - List to Starboard
post #6 of Old 04-30-2013
svHyLyte
Old as Dirt!
svHyLyte's Avatar
Re: List to Starboard
Originally Posted by katsailor View Post
I pulled the batteries last weekend, the only one left is powering the bilge pump and sitting next to the mast. My fuel, waste and water tanks are installed on the centerline of the boat.
Head is located to port and galley to starboard so they should balance each other. Both booms are secured on centerline.
Are you sure the yacht is healing or is the mast out of plumb? Hang a plumb bob from the spinnaker crane at the mast head and see where it ends up on deck. The suspension line should be parallel to the mast all the way down. To check the hull, set a bucket of colored water on the sole amidships in the accommodation. Once it settles, the water surface should be at the same level below the rim from port to starboard.
svHyLyte is offline
