SailNet Community - View Single Post - You are NOT "FISHING"
post #85 of Old 05-01-2013
jackdale
jackdale's Avatar
Re: You are NOT "FISHING"
Originally Posted by johnnyquest37 View Post
Below is from the reference Jackdale provided in his earlier post. Interesting that the commentator says that the master of the vessel must display the lights and shapes in order to claim "fishing vessel" status. For dayshape, two cones with apexes together. I've heard this before but have yet to see it printed from any definitive source.
You referenced Rule 26 yourself. The word "shall" is prescriptive.
Rule 26 - Fishing Vessels
(a) A vessel engaged in fishing, whether underway or at anchor, shall exhibit only the lights and shapes prescribed in this Rule.
(b) A vessel when engaged in trawling, by which is meant the dragging through the water of a dredge net or other apparatus used as a fishing appliance, shall exhibit:
(i) two all-round lights in a vertical line, the upper being green and the lower white, or a shape consisting of two cones with their apexes together in a vertical line one above the other;
(ii) a masthead light abaft of and higher than the all-round green light; a vessel of less than 50 meters in length shall not be obliged to exhibit such a light but may do so;
(iii) when making way through the water, in addition to the lights prescribed in this paragraph, sidelights and a sternlight.
(c) A vessel engaged in fishing, other than trawling, shall exhibit:
(i) two all-round lights in a vertical line, the upper being red and the lower white, or a shape consisting of two cones with their apexes together in a vertical line one above the other;
(ii) when there is outlying gear extending more than 150 meters horizontally from the vessel, an all-round white light or a cone apex upwards in the direction of the gear.
(d) The additional signals described in Annex II to these Rules apply to a vessel engaged in fishing in close proximity to other vessels engaged in fishing.
(e) A vessel when not engaged in fishing shall not exhibit the lights or shapes prescribed in this Rule, but only those prescribed for a vessel of her length.
Navigation Rules Online
jackdale is offline
