SailNet Community - View Single Post - My last little bit of planning
post #69 of Old 05-01-2013
Alex W
no longer reading SailNet
Alex W's Avatar
Re: My last little bit of planning
Most LED running lights use 1-2 watts (usually 2 for the front, 1 for the back, 1 for the anchor). It can vary and older ones would be more.
Does your outboard have an alternator? That will normally supply 2-4 amps at cruising speed.
You need a shore power cable and battery charger to charge batteries from shore power. My Catalina 25 had a shore power cable, but no charger, so plugging it in didn't do anything for the batteries. A charger plus shore power cable cost more than the solar setup, though the cables aren't too hard to find used.
Alex W is offline
