SailNet Community - View Single Post - Marvels Mystery Oil
post #39 of Old 05-01-2013
tommays
tommays's Avatar
Re: Marvels Mystery Oil
I just finished my biannual spark-plugs and water-pump impellers and i got four nice tan spotless clean spark-plugs i attribute a lot of it freshwater cooling because the 180 thermostat lets the motor burn so much cleaner
Gary there are no seals just valve guides so any blow-by is ring or valve related and a leakdown test would tell in a few minutes
Another performance issue comes form raw-water cooling because and amazing amount of stuff builds up in the valve passages below the valves because its so COLD to the point its surprising the motor can run
You cant even see the gunk without pulling a good bit of the motor apart
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
