SailNet Community - View Single Post - Name this prop
Thread: Name this prop
post #9 of Old 05-02-2013
Fstbttms
I don't discuss my member
Fstbttms's Avatar
Re: Name this prop
Originally Posted by Minnewaska View Post
You got me on the brand. Those nuts on the case halves are probably a give away to someone, but I've not seen them. Max-props have hex head bolts into tapped holes, not nuts.
Anyway, I suspect it disassembles similarly. Remove whatever is in those recessed slots at the rear of the prop. It should allow a cap to come off that is holding the blades on. Then, those nuts must be keeping the case halves held together around the shaft.
The nuts secure the pitch adjustment screws and have nothing to do with the removal of the prop.
Here is a link to installation instructions for all of the discontinued Autostream models:
Seahawk: Instructions & Service Advice for Autostream & Slipstream Propellers
Originally Posted by windward54 View Post
Can't be an Autostream if it's bronze. Autostream props are stainless.
Fstbttms is offline
