SailNet Community - View Single Post - Strange noises from below...
post #14 of Old 05-02-2013
Kutter
Re: Strange noises from below...
We suggest movement that = more than 2.5% of shaft diameter as a worn bearing and one that should be changed. Different shaft sizes will run different clearances from new and different manufacturers also run different clearances so ideally you should get the spec from the manufacturer.
Kutter is offline
