SailNet Community - View Single Post - M-34 Cutless Bearing Removal
post #5 of Old 05-02-2013
Re: M-34 Cutless Bearing Removal
Not as common in the States but many shaft bearings are now fitted on epoxy as a clearance fit, to remove these you just heat the carrier and the epoxy softens. No pullers required. Some bearing manufacturers recommend this type of fit.
Kutter is offline
