SailNet Community - View Single Post - Getting sanitation hose over fittings
post #7 of Old 05-03-2013
chef2sail
chef2sail's Avatar
Re: Getting sanitation hose over fittings
Originally Posted by Tim R. View Post
Hot water does the trick. If you tighten your hose clamps down while the hose is still pliable, the hose will conform to the barb and be impossible to remove without heat or cutting.
I would not use this hose myself. The Trident double wall #101 or #102 is a better hose to work with and will last longer.
Totally agree. The green stripe is the way to go.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
