SailNet Community - View Single Post - Soft Sole Replacement
post #8 of Old 05-05-2013 Thread Starter
Squidd
Superior Sailor
Squidd's Avatar
Re: Soft Sole Replacement
Had a couple warm days (finally) so I layed up a bit moreepoxy on the sole...
I had already coated the bottom of the plywood as well as edges, then a layer in bottom of sole cavity...let that harden up...
Then I mixed a batch and poured it in the cracks and gaps around the plywood to tie everything together...I coated the top of the plywood and layed in a wide layer of 6oz cloth over the existing sole...
Then another narrower layer of cloth and epoxy to build up the thickness of the original sole.
When this hardens up, I'll sand the lumps and bumps out and be ready for the final top coat to smooth it all out into one texture...
Not sure if I want to go to the trouble of making molds and trying to duplicate the old non skid pattern with borders etc...or just dust it with silica sand in the wet top coat and then cover with paint...
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
